enblethen
Oct 12, 2015Nomad
The wire should be #10 in 30 ampere cords.
The problem is likely your heat pump and the other electrical loads.
What is the voltage when the heat pump is not running?
There could be a problem with the heat pump. If you have an Amprobe check what the amperage draw is on the pump and compare it to the specification plate on the unit.
38,777 PostsLatest Activity: May 24, 2026
