Grandpa_JoeExplorerOct 12, 2015Wire size on 30 amp RV cablesDo the commercial 30 amp RV cables you purchase from Camping World, Walmart, etc use #10 gage wire or larger? I have 2 of these, both 25 feet long and noticed a 10 volt drop when running the heat pump...Show More
JTExplorerOct 12, 2015If you're using *both* cords between the power supply and your rig, a 10 volt drop over a run of 50' is not unusual.
Related ContentInverter wire size?Daisy chain cable size?Installing 3000 W inverter – wire size – fuze sizeAdding power outlets in slide with no wiringWhat Size Wire 30amp
