Grandpa_JoeExplorerOct 12, 2015Wire size on 30 amp RV cablesDo the commercial 30 amp RV cables you purchase from Camping World, Walmart, etc use #10 gage wire or larger? I have 2 of these, both 25 feet long and noticed a 10 volt drop when running the heat pump...Show More
OzlanderExplorerOct 12, 2015Yeah, the question would be ,What is the voltage at the pedestal under load.I'll bet it's not 120.
Related ContentInverter wire size?Daisy chain cable size?Installing 3000 W inverter – wire size – fuze sizeAdding power outlets in slide with no wiringWhat Size Wire 30amp
