I put mine inside the outside refer access panel. It is mounted just above the lowest vent. When the refer is running, which is when we are using the MH, outside air is being pulled into the vents, and because it's mounted just above the lowest vent and forward (away from the flamebox), it isn't subject to the heat from the flamebox.
It's out of the weather, and yet has outside air being pulled past it.
Like others, I thought long and hard before deciding on this spot. I tried many of the locations mentioned by others in the preceding posts - but was never satisfied with the results. The refer vent seems to be the best for us.
