- j-dExplorer IIAt least with Winnebago, they tell us where the wiring is. And it actually is there. Our Jayco is a mess like OP's pic, both inside and underneath. And so is the patchwork of plumbing under the stove.
- D_E_BishopExplorerI've been in the same situations most of you have been in and believe me just having wiring installed is a well engineered loom is just as bad as wiring being loosely bundled together. Don't get me wrong, I love the thoughts employed by Winnie in most things but a 2' diameter loom carefully and tightly wrapped can be a major problem when it is so tightly run and tightly bound you can't move it.
Another thing that is difficult in trouble shooting Winnie wiring is that almost all the wires used are Yellow or White. The least they could do is use different colors for battery supplied 12 volt lines , ignition ON another and ignition Off For Start another color. Speaker and other media wiring should also be a different set of colors.
When wiring a residence, we always labeled each breaker specifically. Not just outlets, but baseboard outlets in living room or GFCI protected for Kitchen. Out Bounder didn't label any of the CBs, Winnie at least labels the breakers by use. I don't even want to mention OEM fuses much less the add on fuses under the dash or in the engine compartment. - TonijimExplorerToo funny and too current. While making a different repair, our repairman found a switch under the bottom kitchen drawer. He said "I have no idea what this is for - but never turn it off!"
Jim - mgirardoExplorer
StingrayL82 wrote:
And the funny thing is nothing has changed. When I started restoring our 1968 Streamline travel trailer, I found aluminum shavings in the walls. The wiring was disorganized too. Our 1971 Airstream wasn't much better.
At least the aluminum shavings were inside the walls. We bought our Bungalow new back in May 2017. We lived in it for the summer season. When we closed up for the year, we were still vacuuming and pulling up aluminum shavings out of the carpets. We should have collected them and returned them to Jayco as a thank you for the great clean up they did.
Jayco is notorious for messy wiring. Fortunately, I haven't had to dig into the wiring. Hopefully I won't have to find out.
-Michael old guy wrote:
After 13 years I am still collecting some. Almost there.
I got enough saw dust out of my ceiling and under the dinette
to stuff an elephant- Farmboy666ExplorerEvery time I upgrade or add something it takes three times longer because I have to straighten up what’s been done from the factory. This started as a shower diverted install, old one ran off the sink faucet which was horrible. I was trying to figure out the best way to get to the Pex lines under the bathroom floor and it looks like adding an outside shower is my best option to get to the old supply lines.
- StingrayL82Explorer IIAnd the funny thing is nothing has changed. When I started restoring our 1968 Streamline travel trailer, I found aluminum shavings in the walls. The wiring was disorganized too. Our 1971 Airstream wasn't much better.
- camper19709ExplorerUnfortunately a rats nest of wires EVERYWHERE seems to be the norm. To name a few of mine. Converter and inverter and leveler compartments. And dont even look behind the TV over the dash. YIKES.
- mat60ExplorerAlmost forgot that I had to install my stove after I discovered the only thing holding it in was the gas line.
- ScottGNomad
I swear they run a chipper in there prior to delivery.
38,780 PostsLatest Activity: Jul 20, 2026
