blknomad
Mar 01, 2016Explorer
wiring problem
Was stopped for an overnight the other day and the campground cable was off. Turned on TV with booster life is good until I turned on a light and tv went off. turned light off, tv comes back on tried ...
wildmanbaker wrote:
LED's are causing this? lmao! As mention above, its probably a ground that may be feeding back through the TV power plug, killing power to the TV. Remember, there is a relay that kills power to the TV plug, when the engine is running.
