farrelltj's avatar
farrelltj
Wiring the transmission booster for the tire minder
Trying to wire the Tire Minder Transmission booster to the back of our 2013 Thor Hurricane. Book and web site not much help about where the two wires should really be connected. Any suggestions? Thanks. Tom
  • We put ours in the basement area where the power cord is. There was a convenient place to hook up to power. We put it on the wall in that compartment. It is far enough in the back that we get a good signal from the toad.
  • I did mine to the closet light. Power is always hot, 2 minute job with quick splice works great. If you wire wrong the led will not light up. Hope this helps.
  • Red wire goes to the hot side and the black to ground. The red can be connected to any hot wire that is convenient.
