kalsbeek
Apr 11, 2016Explorer
HI
When I expand your battery picture it is obvious they have not been cleaned or serviced for a long....long time. Each battery by itself...needs to read 12.0 volts or more to be effective. Suggest you clean all the connections with wire brush and check the water in each of the cells. If that is good charge them and try again to start and probably all will be good.
Make sure your battery disconnect switch is in the ON position after you have the batteries charged.
38,763 PostsLatest Activity: Dec 05, 2025
