Community Alumni
Apr 11, 2016Moffittclan wrote:
I have had it plugged into 110v the whole time. I understand what you are saying about cleaning and checking the batteries (and I'll certainly try that...but shouldn't the batteries be charging off of the power coming in from the 110v as well? What's the best way to check to see if that is happening?
Also, I tried using the button to use the "house batteries" to start the coach and that didn't work either...but the batteries were running the slides, lights, etc. just fine...
Your batteries may not charge when plugged in I had a neighbor in a Winnie that was plugged in but his batteries did not charge and he had to run the motor he said it was supposed to work that way so I guess it. Depends.
At 7 volts on a 12 volt battery the battery is dead and all the things you said did not work were from one of two things a bad ground or dead batteries.
JimR
38,763 PostsLatest Activity: Dec 05, 2025
