RLS7201 wrote:
rgatijnet1 wrote:
You need to get under your coach and look again. Your OIL cooling lines AND your transmission cooling lines all go through the radiator, NOT the AC condenser, which is out front.
Any vehicle AC shop will be able to order a replacement condenser and install it in to your coach. There are many standard size condenser assemblies out there that will work.
See the oil cooler lines on the bottom of the condenser?
It's a P32 thing.
Richard
Thanks, I stand corrected. On the W chassis, they all run through the radiator. Perhaps he could use a standard condenser replacement coil and ADD a separate oil cooler.
