rgatijnet1 wrote:
It could be something as simple as a loose ground connection in the dash wiring, especially since it happened after hitting a big bump. Since intermittent electrical problems are the hardest to find, I wouldn't worry about it unless it starts to happen on a regular basis.
That is my suspiscion #1 as well. He described what happens in a bad ground situtation to a "T".
On my RV, while working on something else entierly.. I found a bad ground under the dash and tightened the screw.
I also fixed the non-related other issue.
QUESTION: The blasted annoying beeper.. Where is is exactly.. Mine is no longer going BEEP! BEEP! BEEP! (it's going (smaller font) beep beep beep (return to normal font) instead)
