mrracechaserExplorerSep 03, 2020Workhorse oil cooler lines/hosesI developed a pin hole in one of the oil cooler lines that runs from the block to the cooler. This is a common problem when the bracket breaks that holds the lines in place where they go thru the area...Show More
rgatijnet1Explorer IIISep 03, 2020Besides the oil cooling lines there are also transmission fluid cooling lines that can have the same issues.
Related ContentTrans coolers12v coolersfrozen sewer hose and water lineTransmission cooler workhorsesWorkhorse fuel pump replacement
