jeff14's avatar
jeff14
Workhorse problems
While driving on the highway yesterday and hitting bumps in the road my instruments, tachometer, speed odometer, fuel gauge would go off and then all come back on a few seconds except for the fuel gauge. It would take several seconds after that for the fuel gauge to return to its original position and a warning buzzer would sounded while needle was on empty. The seat belt light would stay illiuminated the hole time. This happened for the next 8 hours of driving.
Then after hitting a large bump in the road this happened again but this time a warning came up saying powering down. So I pulled off the highway and turned off the ignition. after sitting there for several minutes I restarted it and it ran fine until the next bump in the road. This time the powering down and code J1850 came on along with the check engine light.
It never seemed to loose power except for the powering down warning. It is a 2008 workhorse with the 8.1 and Allison transmission with 16000 miles on it. We just purchased it last month and this was our first trip. Any help would be appreciated.
  • Check with workhorse about a recall with the cluster, My 2004 had a recall. Some workhorse shops can reflash the cluster while it is in the vehicle. Go to the website and enter your VIN number and ask about any recall for your MH. Also check for a loose ground wire from the cluster and also from the battery.
  • I have a 2008 WH as well. About the same amount of mileage. Never had a problem like that. Sounds like some wiring is loose, a short, or a computer related problem. I would take it to a Workhorse shop to check it out.
  • Sounds like you have a loose ground wire somewhere in your coach. Does your radio work? How about when your gauges go haywire? If it also goes off when you hit the bumps, turn it on loud and start jiggling wires until it goes off. Start with the ignition switch and work under the dash before going under the hood.....Dennis
