okwaterdog's avatar
okwaterdog
Workhorse vs Ford
I am shopping again (!!) and have a question:
Looking for a used gasser, and friends say the Chev 8.1 Workhorse/ Allison transmission is the best choice. Hard to find, because now I am told manufacturers have switched to Ford and GM is no longer making the Workhorse....
My question is: If the Workhorse engine is so great, why aren't they making them anymore?
Second question is: Is the Ford Triton really that different? just as good or to be avoided (what other choice is there?
As always, thanks for responses.
  • If someone is looking for a NEW gasser, so why worry about it? They only have one choice and it is the Ford chassis, period. If they want to go to a diesel, than they will have more choices. They cannot get the Allison transmission on the NEW or used Ford chassis.
    Since you are looking at a used coach, that is already out of warranty, then look for the floor plan that works best for you. Both engines will get you where you want to go and both will get you over the mountains. In some chassis configurations, the WH chassis has a greater towing capacity than the Ford. The Workhorse brake issue has been dealt with and is no longer an issue. The fires in the Ford engines has been dealt with and is also no longer an issue. Parts are available for both chassis and 99% of the items that you will need are available off the shelf at most parts stores. Some like the Allison transmission, but the newer Ford transmission is probably just as good.
    Find a floor plan that suits you and forget about the chassis make because you will never wear out either one of them.
  • I greatly preferred my Ford V-10 to the previous Chevy V-8s in my first two MHs. but what years are you talking about?
    bumpy
  • I have had both and I liked the Workhorse a little better, but not enough to make me pass on a nice Ford.
