racer99 wrote:
We are thinking of buying a older 2002-2006 wrangler which would be auto trans and want to tow it 4 down,are brakes a must or can we tow it without brakes
racer99.
First off, about 99.999% of most Jeeps, hover real close to 4K in weight or over. It all depends on just what's outfitted into/onto the Jeep itself. You put lifts, larger tires and wheels, heavy duty bumpers, nerf bars, roll bars, specialty rear/spare tire carriers, a HARD TOP, and more, you creep up to 4,500-4,700 REAL FAST!
So, even towing it with a large type Diesel Pusher, 4,500 lbs. almost doubles it weight as you try and STOP IT, while towing it at higher speeds. So, SHOULD you have a braking system in it, for common sense sake, YEP, you sure should.
What kind, well, that's up to you. There's a ton of them out there. There are some that somewhat easy to setup and some, are a PITA. Most of them have some sort of arm that pushes on the brake pedal. Some, like Ready Brake, "Pull" on the brake arm with a cable. The one I recently went to is the M & G Braking system and, it has NOTHING inside the toad, what so ever. It's a unit that is installed between the master cylinder and the power brake booster. I really like it. All there is between the coach and the toad, is an air hose.
Now, here's the LEGAL deal. In all but VERY FEW states, it is required to have auxiliary brake systems in your toad. You can go on line and simply do a search for legal towing your toad behind your RV with or without brakes and, you'll find charts that tell you which states demand it and which don't.
My thoughts are, what are you going to do, DRIVE AROUND THE STATES THAT DON'T REQUIRE IT? For a measly few hundred bucks, you're good for ALL FIFTY STATES!! And, this is also one of those things that falls in the "liability" bag. You could be happily cruising in your RV, towing your little Jeep and, all of a sudden, you get banged from the side.
It's not your fault at all, not even close. But, a shyster lawyer will find out you DON'T HAVE TOAD BRAKES and, will turn things around in court of law. You don't think so? It's happened way more than once. So, Your choice. Good luck with your new Jeep.
Scott
