Mike2422ExplorerJun 14, 2018Xantrex 1000Can I just bypass the xantrex 1000 converter and only thing that would happen is no power to tv's unless hooked to campground power or gen. Set is running. Any other problems I should worry about havi...Show More
wolfe10ExplorerJun 14, 2018Is this 1000 watt INVERTER by Xantrex? If so, it has a built in "pass through" feature/ATS.So, yes, one could go from the 120 VAC "IN" to the 120 VAC "OUT" and everything would work on shore power or generator.This does not mean that the proper fuses/breakers are in place, however.
Related Contentupgrade xantrex 1000 to xantrex 1800Xantrex 458Xantrex Truecharge2 Reliability?Honda 1000 ?Allison 1000
