Finished installing the radio and setup to Class A Vista. It was suggested by many to place the antenna in coach, I could never get a signal. Not saying it couldn't be done but I couldn't get it t...
I had it on top of the front cap frame (inside the coach) at first, but the signal through even that small amount of fiberglass was weak. Finally I poked the antenna wired through the CD antenna penetration and glued it to the frint cap. I stuck the wire down like 10forty2 did.
