Sam_Spade
Jan 31, 2018Explorer
ron.dittmer wrote:
- front wheel alignment which required offset bushings.
The difference went from a drunken sailor to a stead-as-she-goes experience.
First place I went to told me that the front end was "worn out" and needed $3000 in repairs before they could do an alignment using the procedure that I printed out from a post on here.
I walked. It wasn't old enough to be "worn out".
The second place looked at the sheet I gave them and said "Sure. We've done that before a few times." About $300 later and it was rock solid; well, as solid as a big "box truck" can be if the wind is blowing.
Which is why I suggest doing the alignment part FIRST to see what the result will be.
Doing ALL OF THAT EXPENSIVE STUFF at the same time won't allow you to know which parts were really necessary and which not.
But......it's your time and your money and you need to do whatever YOU think is right......for you. That doesn't mean that it is right for everybody though.
38,782 PostsLatest Activity: Sep 10, 2026
