turbojimmy's avatar
turbojimmy
Yet another furnace question
I've read a lot of threads on furnaces, but haven't come across one like this. Naturally the furnace worked fine last winter, but now that I'm actually camping in the RV it's decided to act up.
It will work normally every time on a cold start up. Fan runs for a bit, ignition fires, warmth ensues, it shuts off when it reaches the desired temp. The issue is when it restarts.
It first started doing it last weekend. In the middle of the night it felt cold. I heard the furnace "click" when the thermostat called for heat, but it didn't do anything. After shutting it off and turning it back on with the ON/OFF switch at the T-stat it fired up and was fine for the rest of the night.
This morning, however, it wouldn't fire up. I would shut it off and turn it back on, hear it click, but no fan.
I took the cover off and spun the fan with a long screwdriver. It seemed okay. I then turned it back on. The fan ran for less than a second. Shut off. It tried again by itself - fan ran for less than a second, shut off. I shut the switch off and turned it back on. It did the same thing. On the third try the fan ran as it should, burner fired up and we were off to the races.
So....failing fain?
  • The fan should run even with a bad sail switch or thermal cutout.
    I would test the thermostat.
    Remove the cover, locate the two wires going to the furnace. Connect them together. Fan should start, furnace should ignite and produce heat if 10-15 seconds. Run furnace in this mode for a few minutes. Separate the two wires, furnace should go into cool down mode and shut off in 15-30 seconds.
  • rgatijnet1 wrote:
    Sounds more like a failing switch/control board.
    Any guess around which switch? There's 2 right - sail and high-temp cut out?
    And...I'll pull the fuse just for fun to see if it clears up.
    It's a 1984 vintage furnace, but I can tell the guts have been out of the case and replaced. Despite it's age, it is electronic.
  • Pull any 12 volt fuses related to your furnace, wait for a minute or so, then put them back in. I don't know if this will work, but this procedure has "fixed" several problems with electronics over the years. In fact, it just worked for my friend who was having a problem with his brand new Norcold four door refrigerator.
    Bruce
