RVcrazy's avatar
RVcrazy
9 x13 pan?
Will a 9 x 13 fit in an RV oven and still leave a bit of space around the edges for heat distribution? Thanks!
  • The 15" X 15" is very close to what is in our fiver. A 12" deep dish pizza pan would probably work well.
  • I could drive to where I store my RV and measure my oven for you, but you still wouldn't have a good answer. You need to measure your oven.
  • Super_Dave wrote:
    Quality Johnson wrote:
    A 12" Dutch oven has the same capacity as a 9X13 pan. Just sayin'.
    But that will definitely not fit in the oven. 9" X 13", 1 and 12" dutch oven, 0. ;-)
    Entirely true, and I would not suggest trying to use the Dutch oven in the camper oven. Buuuuut, put that Dutch oven outside with charcoal under and on it, and there you go. Not what the OP wanted to know, but I just wanted to suggest an alternative, since correct answers had already been provided to the original question.
  • I don't think all RV ovens are the same size but I know some (maybe most) are 15"X15" so the pan should fit fine.
