GordonThree
Dec 30, 2017Explorer
Any hints for grilling in moderate cold?
Right now it's 8 F (-13 C) which isn't extreme cold, but it is a bit unpleasant
Would like to do some St Louis style ribs for NYE tomorrow... I know I won't be able to smoke them, my simple weber kettle looses heat pretty bad under 40F, no way I could do a low and slow with it.
Thinking a hot indirect blast for an hour our so, to get some smoke on em, then wrap in foil and finish in the oven for a few hours.
Tried lighting a chimney of coals and after the Weber starting cube went out, the coals that were smoldering just gave up and the chimney went out.
I'm worried that even if I get a chimney lit the coals will just go out, and certainly won't light the wood chunks to get the smoke going.
Any suggestions?
Any suggestions?
