Need-A-Vacation's avatar
Jul 23, 2016
Camp Kitchen "Set Ups"
We do 98% of our cooking outside, usually either on the Weber Q or the Camp Chef Explorer 2 burner stove under a 10x10 Ez-Up. Trying to come up with an easy to assemble rack that is compact for storage, to hang the cast iron skillet pans from above/behind the Camp Chef. One that is about 6' tall, maybe 4-5' wide. I may have room to store it in one of the fence post sleeves, or could add another one if needed.
I have considered using 1/2" or 3/4" black pipe, or pvc (fear it will be to weak). Thinking basic U shaped design. A tee with 12-18" legs on the ground, then screw a post into the tee. Then either an elbow (or tee) the post would screw into for the horizontal pan hanger, or a larger elbow that will slip over the post and pin it to make it a little easier.
So, any ideas? Have 5 skillet pans, plus the 2 Camp Chef Pro griddles which have some weight to them. I plan to hang a griddle on each side either just outside the post, or just inside the post.
If you have pics, please post them.
TY!
  • Need-A-Vacation wrote:
    magnusfide wrote:
    Are you wanting something like this Deluxe Camper's Kitchen?
    Or perhaps this one??
    Have you thought of using 3/4" iron plumbing pipe?
    TY for the suggestions. I'm not looking for a prebuilt setup with table space, already have a couple roll top aluminum tables.
    I have considered using 1/2" or 3/4" black (steel) pipe from HD or Lowes. Just looking for possible other ideas, or designs if someone has already made something similar.
    I'm a little confused. You said you wanted ideas and thus I also thought some prebuilts could give some TNT inspiration. Here's another idea using tent poles. Just imagine the space w/o the table:):
    Check out 3rd Picture Down
    Pages of ideas on pinterest too:
    https://www.pinterest.com/pin/79376012156531241/
    I use the Cabela Deluxe Camp Kitchen for my long trips whilst tenting but am on the lookout for something more compact for cooking outside in the RV:
    Currently having a feud with Cabela's so won't be buying anything else from them in the future but will say I got my money's worth from this specific product. Only 2 disadvantages: It's heavy (weighs about 50 lbs.) and the material the countertops are made of are chintzy IMO. In general I only carry 2 CI pots (6" and 12" skillets)and the camp kitchen holds them securely along with other kitchen utensils and pots.
    Not sure of the weight load of the 3/4" pipes magnus recommended but I do know those pipe makes great curtain rods and are in use in my D/R holding double lined drapes which prolly weigh about 175 lbs in total.
    I would also consider using aluminum alloy tent poles since they break down nicely for storage purposes and come in a variety of sizes and shapes.
    HTH!
