fpoole
Aug 30, 2015Explorer
Inverter? set up 4 - 32"TV, BluRay, DISH, Winegard
There's an excellent thread on inverters in general here for reference
I'm looking to set up the above in an AF 990 and thought I might not be alone. Tried to search, but spotty at best so titled it for easy reference.
Getting the AF in a few weeks, going to try to have dealer set it all up and wanted some ideas.
I'll be setting up the above referenced 32" TV which would have different power? draws than a 9" TV?.
I was looking at a 300 watt inverter but they only seem to come in 1-2 plugs and I'm not sure what is directly connected and what can be done. I'm guessing I'll have it in the TV/Media compartment.
As I see it:
TV = 1 120v plug access
Blue Ray = 1 120v plug access
DISH box = 1 120v plug access
and the Winegard Dish-dish?
Will that require an additional plug access, now total of 4 plug outlets, or are they normally "Hard Wired" in.
AF will have 2 29s battery with 2-160 watt solar panels = 320 watts, on a sunny day?
TV will be on for apx 4hrs day off/on, along with the BluRay for movies at night.
I am wondering for those that have a similar set up, does it work ok? or do you have to be careful on usage or it's just not going to happen unless I Gen it.
I am considering "Hanging" two additional batteries using the Torklift truck hanging batteries with 2 31s... but thinking the wiring, hopefully they are able to do this, would be a mess.
So, with this in mind, open to suggestions and thoughts and hopefully it will help others looking for like setups. Go Simple, Electrical Tech I'm not, have trouble plugging in USB cords, so be forewarned.
Please, if you have suggestion, give the brand names so I can search for it.
Posting the "I have 400 watt and it works great...." leaves me to try to figure out which is the best or better and that can be a scary thought, heheh, so if you have the brand name it's helpful to post it and I can take it from there.
Thanking you ahead, looking forward to getting out there....
and, I know, I know.. what am I doing getting a camper just to watch TV.. heheh, for the noise, and???? cause I can, LOL sigh, I need to hit the road soon...
fun....
As I see it:
fun....
