- Jon_WExplorerIt is safe to use if it doesn't leak fry away. Many people use cracked skillets. Go to this site you will learn a lot. http://www.griswoldandwagner.com
- twins89ExplorerProbably most likely used for decoration. If you want to clean it up nice to hang put it in your self-cleaning oven for 2 hours. Then rinse it after it has cooled. If there is any rust, scrub it off with a scouring pad. Then give it a nice coat of coconut oil and hang it up. Then look for a Griswold or Wagner Ware at a flea market or antique shop. The new ones are much heavier and not nearly as smooth. Don't be put off if it looks grubby. Follow my directions above and then just reseason it a few times by coating with the coconut oil and baking in the oven a few times after you have done the self-cleaning in the oven.
- YC_1NomadThey make great decorations. Buy a new one.
- chloe2008Explorer:( I was looking forward to that fried chicken.
- TucsonJimExplorer IIIt can be repaired by welding. But it might be less expensive to replace it.
Cast Iron Skillet Repair
About Chefs on the Road
2,136 PostsLatest Activity: Jun 27, 2014
