Super_Dave's avatar
Super_Dave
Explorer II
Mar 18, 2017
Davey Crockett spring legs
Wasn't at all happy with the instability of the Davey Crockett spring legs so I came up with this as a solution. 4 - 1 1/4" pipe couplings. Much better now.
  • JoeH's avatar
    JoeH
    Explorer III
    GoPackGo wrote:
    I have been reluctant to set mine on a picnic table and use it. Seems like it could scorch the wood beneath it, especially if I cook at higher then smoking temps (I know heat travels up). Do you have a concern that way ? Do you think that laying down a layer of aluminum foil would reflect enough heat to matter ? Maybe use something else ?
    Thanks.
    What they gave us at Grizzly RV Park in West Yellowstone was a piece of foil backed insulation ( like you get at HomeDepot for your house walls) about 2ftx2ft to put under our grill to prevent scorching their tables. It was a requirement per their rule sheet.
  • I have been reluctant to set mine on a picnic table and use it. Seems like it could scorch the wood beneath it, especially if I cook at higher then smoking temps (I know heat travels up). Do you have a concern that way ? Do you think that laying down a layer of aluminum foil would reflect enough heat to matter ? Maybe use something else ?
    Thanks.
  • GoPackGo wrote:
    How did you attach them ? Or do you just set the springs inside them ?
    The springs are about 1/4" shorter than the coupling. I just set the legs in the coupling on a picnic bench.
  • Nice Dave.
    Now I need your review of how this smoker/grill does.
    Looking forward to it.
  • How did you attach them ? Or do you just set the springs inside them ?
