garmp1 wrote:
I, also am in the market for a wireless thermometer, but for a slightly different application, to work with our dutch oven. Which brings me to two concerns: 1) will the wire when between the lid and body cause any issues in the oven not getting even heat? and 2) will the lid and body while lying on the wire transmit temperature from the metal and give false readings, and/or should this wire be foil wrapped to avoid this.
theDO.
Thanks for any and all help.
Biggest problem I see is thatthat there will be a gap that will allow heat and moisture to escape, which kind of defeats the whole purpose of the DO. And yes, I think it will negatively affect heat distribution.
