Super_Dave's avatar
Super_Dave
First cheese smoke of the season
I bought a new smoking gadget called an A-Maze-N smoke maker. Used it for the first time on my cheese smoke today. With ice, I actually saw a 5 degree drop in ambient box temp. Great for cold smoking situations. As a test run, I only did 8 pounds today, 4 of medium cheddar and 4 of Colby.
Box temp was 63 degrees when I turned it on this morning. 1.6 hours later and sitting at 58. ::)
Now just have to wait for cheese to mellow in the frig for a couple of weeks.
  • So its lit with a torch and smolders... Got it
    u got me thinkin'..
  • SCVJeff wrote:
    So you are using ice to attempt to offset the heat generated from the element?
    With the A-Maze-N, the smoker element wasn't used at all. The ice does offset any heat gain though.
  • So you are using ice to attempt to offset the heat generated from the element?
  • SCVJeff wrote:
    Details!
    What is that box, a smoke maker? How do it do what it does?
    The second picture is just a shot of the smoker's controller which has both box temp and meat temp read outs. Since I don't have the meat temp probe plugged in, it is simply reading time.
    This is a picture of the A-Maze-N device that I tried out for the first time today. I loaded it with half pellets and half sawdust. The sawdust side burned for over 2 hours. The pellets didn't stay lit for more than about 10 minutes.
  • Are you using the A-Maze-N tube or maze? I use the maze to cold smoke pork belly for bacon. In fact I am smoking a belly tomorrow. I can get about four hours burn time and that is with lighting both ends.
    Info on the products can be found here:
    A-Maze-N Smokers
  • We definitely need more details, please. I just finished smoking about 50 lbs of Alaskan Salmon.
  • Details!
