wca01
Apr 06, 2014Explorer
Non-Stick Mistake and Cure
I made about 4 quarts of Tomato Crab and Jalapeno Soup that contains two cups of heavy cream using a NuWave induction eye and a Circulon non-stick stock pot.  The gallon of soup had to be brought to a boil and after adding the crab brought back to a boil.
It was taking too much time to bring the soup to a boil at a setting of 375F. The NuWave can be set to 525F, and I did just that to speed things up. Things went very well, the cooking time was short, and the soup was good. Then when I cleaned the stock pot things turned very bad. The high heat and heavy cream left a mess on the bottom of the non-stick stock pot that wouldn't come off. Well I knew enough not to use anything abrasive on the non-stick surface.
Circulon is the best cookware I have ever owned, and it was time to read their instructions. They state very clearly not to use high heat on non-stick products, and never use anything abrasive for cleaning.
There, somewhere in the instructions was the advised method to get rid of the gunk on the stock pot bottom.
Mix 1/3 vinegar with 2/3 water and boil for 5 to 10 minutes. The pot was clean even before the recipe started to boil, but I let it boil anyway.
If you don’t already know about this trick, file this gem away for future use.
Good Luck!
Wil
Good Luck!
Wil
