You most likely know that NuWave is a stove top induction unit. It comes in two versions, the PIC2 and the pro version. The PIC2 is rated at 1300 watts and the Pro at 1800 watts. I have the Pro. ...
The Nuwave induction is available at Bed , Bath , & Beyond for about $95 - a $20 coupon discount .
It also comes with a frying pan . I use mine everyday , as I like to cook on the picnic table outdoors .
You can put a sheet of newpaper between the cooking surface and your pan to make clean up easier . The paper will not burn and makes splatters easy to clean up . I use a separate 110V extension cord from the post or gen to power my cooking devices
