I am looking for a propane stove that can be easily regulated. We have the basic Coleman which sounds like a jet plane when you start it and is hard to regulate. Looking at more expensive units if t...
The secret to control on the big burner stoves is to use a variable psi regulator. A straight pressure regulator provides full blown pressure and the stove knobs can't deal with that. A variable psi regulator allows one to reduce gas flow before getting to the burner knobs.
