- JaylaExplorerHey! I also put my cole slaw on the bun! Great minds think alike....
- amandasgrammaExplorerI simply put the pork loin in the slow cooker, add salt and pepper and sliced onions (how many depends on my mood). I add about 1/2 cup water. Cook until it pulls apart. I then put the loin on the cutting board (sometimes it pulls apart before i can get it there) and "pull apart". :) Then I put it all back in the now empty slow cooker, add a LOT of Sweet Baby Rays BBQ sauce, heat till that's warm and VOILA...you have pulled pork. Best way to EAT it is on Hawaiian buns with a topping of cold slaw ON the BBQ pork -- not as a side dish. :) :)
- billkaufmannExplorer
donn0128 wrote:
There are several slow cooker rubs available in the spice isle of your local grocery store. McCormacks makes one that we have used several times.
Thank you but, our local grocery store is 60 miles away.:):) - billkaufmannExplorer
Super_Dave wrote:
I either use a can of Coke or a can of chicken broth for my liquid. I don't care for sloppy pulled pork so use a tablespoon of liquid smoke per 2 pounds of meat. The meat will take approximately an hour per pound on low, depending on the output of your crock pot. Once it is done and shredded, I let each sauce their own serving.
Thank you SuperDave. I will try this one for sure. - Super_DaveExplorer III either use a can of Coke or a can of chicken broth for my liquid. I don't care for sloppy pulled pork so use a tablespoon of liquid smoke per 2 pounds of meat. The meat will take approximately an hour per pound on low, depending on the output of your crock pot. Once it is done and shredded, I let each sauce their own serving.
- donn0128Explorer IIThere are several slow cooker rubs available in the spice isle of your local grocery store. McCormacks makes one that we have used several times.
- Campfire_TimeExplorerWe use a rub from Robert Irvine on the Food Network. Put the rub on the meat, marinade it for at least a few hours. Overnight is better. We typically are using a pound of pork roast, but the rub can be varied as needed. Put it in the slow cooker with a cup and half of water on low for 8 hours. Break it apart and add your favorite BBQ sauce and cook for 1-2 more hours. Very simple and VERY good. You can vary the heat factor by what type of BBQ sauce you use.
You can experiment with different rub combinations. We've found throwing your own together is far better than buying a premixed one.
About Chefs on the Road
2,136 PostsLatest Activity: Jun 27, 2014
