Go_Dogs's avatar
Go_Dogs
Romertopf Clay Cooker
As mentioned earlier-got one at the Thrift Store. Did some research. The one I got is the RECO type, (IE-made in Mexico). This one is unglazed on the entire inside. Romertopf no longer makes them in Mexico, only Germany. They have started to glaze the bottom piece to help with clean up. Mine has been used as there are food stains on it. It is Terra Cotta type clay. You're never supposed to use soap or chemicals on it. Clean it with water/stiff brush and maybe salt or baking soda.
Some recipes call for the entire pot to be soaked in water before use. You must put your food in the pot, close it and put it in a COLD oven. It will crack with fast temp changes.
I have it in the oven as I type-Beggar's chicken. The soaked clay should make a steamy environment.
After this, I will attempt a loaf of olive bread,(if it doesn't crack). I'm going to assume, there might be a hint of ginger/garlic in the clay from the chicken which might be ok with an olive bread.
I'll give you an update when all is said and done!
  • Many years ago I had some kind of chicken and garlic roasting in my clay baker and the house smelled divine. Our neighbor across the street stopped in to visit, as her husband was at a convention out of town. I said "I think you should come back and eat later" and she said "I think I should too!"
  • Just took chicken out of the oven. Very, very moist! I used a garlic/ginger, Asian inspired sauce. An hour and a half with the lid on at 425 F and then 1/2 hour lid off. I used 5 big leg quarters. I soaked the clay baker, put in the ingredients, I covered the bottom with parchment and sprayed the inside with olive oil. Put it in a cold oven, turned it on to 425. After about 15 minutes, we started to smell the garlic.
    I am very happy with the results and can't wait to try a loaf of bread. I will feed my starter at bedtime and shoot for Friday,(depending on how active the starter is)!
  • Penzey's makes one called, 'Tuscan Sunset'. If I don't have that I use lemon zest, olive oil, and dried thyme. If you have some fancy-schmancy coarse salt-that's nice, too-adjust salt for the olive brine.
  • You should get a good oven rise with the steam available.
    Do you season your olive bread? I make one with my artisan recipe. I add sliced green olive, jar with pimentos, and Kraft's cheese crumbles, 4oz each. I keep thinking it could benefit from an herb, but I haven't been able to decide on one.
