My Creekside has the tap for High Pressure between the tanks on the tongue. It came with a 12' hose to go into that tap then to the gas grill in place of the small cylinder. I suppose the idea is I put the gas grill on the tailgate of my pickup and hook the hose up there. I think this is sort of, well, Mickey Mouse. I am running a High Pressure 3/8 stainless line from between the tanks to my gas grill location so I can use short hose, say 4 feet that is right there by the gas grill mount. I have sourced all bullet proof(high pressure)stainless fittings and a ball valve at the tap between the tanks so I can shut it off when not in use. I may take the hose connection off the tap at the tank and use it at the gas grill location and use the existing tee for my new tap. Life will be better with this.
