Kebamo's avatar
Kebamo
Salisbury Steak Casserole
If you love Salisbury Steak, then give this simple 30 minute Salisbury Steak Casserole a chance.  Easy, delicious and perfect weeknight meal!  This also reheats and freezes well!
INGREDIENTS
2 - 3 cups pre-made mashed potatoes - leftovers work great!
1/3 can + 2/3 can (10.5 ounce total) can of french onion soup, divided
1 1/2 pounds lean ground beef
1/8 teaspoon black ground pepper
1 (10.5 ounce) can cream of mushroom soup (or cream of chicken if you don't like mushrooms)
1 packet of dry onion soup mix
3 Tablespoon all purpose flour
1/4 cup ketchup
1/2 cup water
2 Tablespoon Worcestershire sauce
1 teaspoon mustard powder
sliced mushrooms (optional)
1 (14.5 ounce) can of french cut green beans, drained
Instructions
1. Preheat oven to 350*F
2. If mashed potatoes are not already prepared, prepare now.
3. In a deep skillet, combine 1/3 can of french onion soup, ground beef & pepper. Cook until meat is cooked through. If using a higher fat meat, drain liquids.
4. While ground beef is cooking, in a small bowl combine remaining french onion soup, cream of mushroom soup, dry onion soup mix, and flour until well combined and flour isn't lumpy.
5. Add to soup mixture ketchup, water, Worcestershire sauce, mustard powder and mushrooms. Mix well.
6. If you have a heavy duty skillet that can go in the oven (no plastic handles) then you can just layer everything it your skillet and bake it. If you do not, or are not comfortable baking with your skillet, then a 9 x 13 pan would work too! If you are doing the 9 x 13 pan, transfer meat mixture into pan now.
7. Pour soup mixture over ground beef.
8. Dump and spread green beans over ground beef.
9. Top with mashed potatoes.
10. Bake for 20 minutes.
11. Serve immediately.
1 Reply
  • I have been making Salisbury Steak lately just using Campbell's Soup Recipe found online.
    https://www.campbells.com/kitchen/recipes/simple-salisbury-steak/
    It is simple and turns out great!
    I do add a small can of mushroom stems and pieces chopped up.
    I also make extra and freeze it.
