Wanderlost's avatar
Wanderlost
Nomad II
Nov 13, 2015
Zucchini-Tomato Salad
1 medium zucchini
3 Roma tomatoes
Peel and dice zucchini. Salt and set aside.
Dice tomatoes and set aside.
By the time you've finished the tomatoes, the zucchini should have mellowed nicely. If it's still bitter, let it sit in the salt a while longer. Then rinse lightly, pat dry, and add to the tomatoes.
Chill, then serve. Does not need any dressing.
2-4 servings, depending on veggie sizes.
Can substitute a can of diced tomatoes for fresh. Just drain as much liquid off as possible before adding the zucchini. You might need another zucchini, too.
