Crowe's avatar
Crowe
Jesse's skin issues revisited-suggestions needed
We've isolated MOST of Jesse's skin issues as an allergy to chicken. We've also determined that when he it gets hot he seems to break out in little bumps. He was groomed last Monday, so his fur is short and dethatched. Mid-week we had some very hot and humid weather, then rain, but it's cooled off again. Tonight he has lots of smaller bite-sized bumps along with his "normal" allergic reaction bumps, both of which become white and scaly/scabby but don't bleed nor is he really itching. Betadine baths do help. Our vet has put him on antibiotics in the past but he seems to react to the antibiotics and gets worse. He eats Blue Buffalo Salmon and Potato food with a little cottage cheese. Thoughts on what it might be and possible prevention/treatment? Our vet seems to be a little stumped as it doesn't respond to antibiotics like an infection would. Thanks.
  • Kidsgone wrote:
    BTW, he was very allergic to plastic bowls...even had a hairless ring around his nose where he touched it while he ate.
    Give it a try...
    Good point! Plastic bowls harbor bacteria more than other surfaces anyway. After I switched Maddie's food bowl to ceramic and her water bowl to glass, she did better, too.
  • Could it be a heat rash? Have you noticed if your dog is worse after being out in the yard, especially if the grass is wet from the dew or rain? Your dog could have an environmental allergy. My westie mix, Maddie's, allergic to grass, which makes her itchy, especially when the grass is wet in the mornings. Giving Maddie a foot soak with a mixture of 1/2 organic apple cider vinegar (ACV) and 1/2 water helps (I keep some of the mixture in a tupperware type container with a lid). You could also use a washcloth to gently apply it to your dog's affected areas if above his feet. ACV has antifungal and antibacterial properties. After you do this, pat, don't rub the excess off. If he licks it, it won't hurt him - ACV is good internally, too.
    Another thought: do you notice this problem more right after applying flea medication each month? If so, he could be allergic to the flea treatment.
    I bathe Maddie with a shampoo that has tea tree oil in it - soothing for itchy skin. Your vet should also have a medicated shampoo he can prescribe if it's really bad. You'll need to bathe weekly while the allergy's bad; more often if your vet prescribes it. If your dog ends up being allergic to grains, bathing with an oatmeal shampoo can actually aggravate the problem.
    If that's not it, have you tried cutting out the cottage cheese to see if that helps? Some dogs are sensitive to dairy.
    If neither of those things help, I'd look at the kibble. Some of BB's formulas are labeled like they're grain free, but when you read all of the ingredients, they actually have some grain in them. Check the ingredients out carefully on the one your feeding. I'd try a completely grain free food (grains make Maddie go absolutely bonkers itching and scratching!). She is allergic to all grains and also potato, in addition to chicken, eggs, and alfalfa. Some dogs can't handle dairy, either. BB has caused some problems with a lot of sensitive dogs. You might want to try one of Natural Balance's LID formulas (limited ingredient diet). They have several that are grain free, and one that's also potato free. That way, you can more easily narrow down what's causing the problem. Nature's Instinct also has a couple of LID formulas that are grain and potato free. Earthborn's Meadowfeast is grain and potato free (lamb based).
    Make sure you don't change too much at once, or you won't know what works and what doesn't. For example, if you change the food, only go completely grain free at first and not also potato free, to see if that helps. Make one change at a time. It may take awhile to see improvement - sometimes a couple of weeks. If the change makes him worse immediately, then you know it's a problem. Maddie's so sensitive, that I can tell within 30 minutes if a kibble is going to work or not.
    Pinpointing allergies is very frustrating, I know. I hope you find out your fur baby's problem soon!
  • We have labs and they are known for skin problems. We went thru a terrible period with our big guy...Tank...and after trying different food, changed his bowls to stainless steal and numerous other things, our vet recommended to bath him once a week for a month with Head and Shoulders. He also told us to go to Walmart and get their brand to save money. Well, that was 5 yrs ago and I haven't given him antibiotics nor prednisone for itching. I lather him with the Head and Shoulders and let it sit on his coat for about 5 minutes then rinse. His coat is very shiny and we are often asked what we use to bathe them (he has sister). It really is amazing. We only bathe once a week if we notice him starting to scratch...then back off after about 3 weeks and back to their normal schedule. BTW, he was very allergic to plastic bowls...even had a hairless ring around his nose where he touched it while he ate.
    Give it a try...
