jag70r's avatar
jag70r
am radios
Can someone recommend a good portable am/fm radio that I can wire into my existing roof antenna on my 5th wheel? Thanks
  • Here is another option for a AM Antenna.
    Search "select-a-tenna" on Ebay.
    I have one. They work real good. Simple to use.
  • I use Wi-Fi to listen to AM radio stations 2,000 miles away. I Heart Radio is one option.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    NO.. and here is why.. the antenna on the roof is VHF/VHF UHF with the FM band blocked out (It is between vhf low and vhf high)
    AM is either LF or HF (on da border)
    Or in other words.. That Batwing is designed for six meter band up through band lengths measured in centimeters.
    AM is the 300 meter band. The proper antenna is 150 meters long (two 75 meter sections) A meter is a bit more than a yard.
    What you can do with any AM portable.....
    Take a LONG wire (Say 75 meters) and hook one end to a ground rod.. Wrap 2x around radio.. Hook other end to a line and on the other end of the line (Nylon roap works well or even anchor line, NON WIRE CENTER) Put a couple pounds of weight (I use a concrete thing) on the free end of the line and toss over trees.
    That's how to make an AM radio antenna connect to any AM radio.
    That said.. I can do AM band with my kenwood TS-2000 ham rig.. It does connect to an antenna on my roof (A 1/2 inch copper pipe that runs the length of the roof) but it is not portable. And the cost is a tad....High.. Works well though
    Normally I use it with a 80-100 feet of long wire. here it's 50 foot.
  • I use a Superadio. They were made in GE, RCA and Radio Shack brands. You can probably find one on EBay. Some models did have external antenna connections. Google Superadio and you can find much information.
  • RoyB's avatar
    RoyB
    Explorer III
    I have had mine since 2008 - no problems with it and mine is the older CC RADIO PLUS model. I use it just about everyday doing something even here around the house.
    Roy Ken
  • My CC Radio has 2 screws on the back for connecting an antenna.
    The older model radios had problems with the digital readout and tuning,
    Hopefully the new model is better.
  • RoyB's avatar
    RoyB
    Explorer III
    The best portable radio I ever used was the C CRANE model CC RADIO PLUS available from AMAZON... It may have been replaced with the CC PLUS RADIO-2E now...
    Runs on four D-CELLS and has a long use time between batteries. Very Excellent AUDIO quality... Also includes NOAH WX ALERT RADIO as well...
    Get the nice carry case also...
    Roy Ken
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 19, 2026
