rk911
Jun 27, 2016Explorer II
Old-Biscuit wrote:
You have to know which direction are the TV Transponder Towers, how far away they are and IF you can get the channels.........
This will help you find that info......LINK
Or this one........LINK
Enter the CG information (address/zip code etc)
Move pointer to your exact location for better info
Then 'AIM' the front (HEAD) of antenna in direction indicated
Then SCAN for channels
if you're going to go to all that trouble remember that the broad side of the batwing antenna is where the signals are captured...not the ends. for example, if the transmitters are north of your location you would point the batwing so the arms point east and west.
but, it's a lot faster and easier to either point your batwing antenna the same way as your neighbors in the CG OR orient the antenna wings north/south and scan for channels. then re-orient them east/west and re-scan to see which produces the better result.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
