rk911
Jun 27, 2016Explorer II
dockmasterdave wrote:
I believe typical broadcast range is about 60 miles, from the transmitter.
and that assumes flat terrain with no obstacles between the receiving and transmitting antennas. TV is line-of-sight so the higher the receiving antenna the greater the reception range. coax does have a useful life. constant exposure to UV will deteriorate the jacket. the single best thing one can do to improve reception on an older RV/TV antenna is to change the length of coax (RG-6 recommended) between the antenna and the rooftop connector.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
