KD4UPL wrote:
I don't think the OP is confused at all. He's got 2 terminals labeled for an AM antenna. It's likely a 300 ohm input.
A TV antenna probably won't do much but I guess you can try it.
Do you have an attic? Make a big loop of wire around the attic and put the ends into the AM terminals.
If that radio has an AM antenna its for a typical center tapped antenna, you don't just a toss bunch of wire around and short it out at those frequencies, you'll likely wind up with a worse fix. A consumer AM antenna is typically an open ended longwire, unless it's a car antenna and those are typically 90 ohm coax. IF the back of the radio really has two terminals, one is likely a ground while the other is 'hot'. If he can't string a long wire (even 6' makes a difference), then Chris's active antenna is by far the best solution and might be the only thing a casual non-technical listener could use because it works. The other option is a small tunable passive loop
But a TV antenna is completely useless for this
