covetsthesun wrote:
SCVJeff wrote:
KD4UPL wrote:
I don't think the OP is confused at all. He's got 2 terminals labeled for an AM antenna. It's likely a 300 ohm input.
A TV antenna probably won't do much but I guess you can try it.
Do you have an attic? Make a big loop of wire around the attic and put the ends into the AM terminals.
If that radio has an AM antenna its for a typical center tapped antenna, you don't just a toss bunch of wire around and short it out at those frequencies, you'll likely wind up with a worse fix. A consumer AM antenna is typically an open ended longwire, unless it's a car antenna and those are typically 90 ohm coax. IF the back of the radio really has two terminals, one is likely a ground while the other is 'hot'. If he can't string a long wire (even 6' makes a difference), then Chris's active antenna is by far the best solution and might be the only thing a casual non-technical listener could use because it works. The other option is a small tunable passive loop
But a TV antenna is completely useless for this
Ok. OP here. I am not confused. My gizmo has the capacity for both an AM Loop and FM also. My AM Loop just isn't strong enough to pick up a few of the AM stations we want to listen too. If by terminals you mean a place to insert wire and then push down a latch to hold it in place...then I have 2 terminals for AM and 2 for FM. If I take a certain wire out... there is no sound. So, one may indeed be a ground wire.
IF it had a jack (female) for me to plug into.. I could go to Best Buy and get an AM antenna. But.. It does not. I'm wondering if I could get the BB AM Antenna and just cut off the jacks and insert bare wire into my radio. An expensive experiment though.
By the way... I, the OP..am a she. Not a he. However, I am my Father's oldest son. :) He wanted a boy... got me and decided that girls could hunt and fish too. :B
I never said you were confused, someone else did. Check it out.
Anything will work for a receiver.p, AM broadcast band isn't picked at all. If you can get this BB antenna outside you may do better than a longer antenna in a cabinet. You can also try 20' of wire wrapped tightly around a broomstick to form a coil and remove the stick. Hide it in a cabinet and see how it works, you might be suprized. And No, you don't need a ground.
Or just go with that active loop that Chris linked to
(Edit spellin')
