- LittleBillExplorer
joebedford wrote:
LittleBill wrote:
The Bullet is operating in router mode. I might be wrong, but I don't think there's any security between it and my router AP.
thats cus the bullet is working in client mode, it has to match whatever the campground security is, you connect to the bullet via the linksys router and configure the wireless security settings there.
As an experiment, I'll change the password in the Bullet for my test network and see if it still logs in or if the PC is doing security.
there is AP Access Point Mode, Station Mode. this is not the same thing as Router, bridge mode.
You are in station mode, this is shown on the main tab on the bullet.
Your question was why can't i change security settings on the bullet, this is because your security has to match what the campground or wherever your getting your internet from. Your linksys is what YOU connect to, and is in Access Point mode. here is where you can configure your security settings. - joebedfordNomad III
Bill.Satellite wrote:
What was cheaper or easier 5 years ago when I bought mine?
Why does anyone buy any of the WiFi Ranger products when cheaper, easier to operate systems are out there? Sorry, rhetorical question....I just don't get it. - Bill_SatelliteExplorer IIDup.
- Bill_SatelliteExplorer IIWhy does anyone buy any of the WiFi Ranger products when cheaper, easier to operate systems are out there? Sorry, rhetorical question....I just don't get it.
- joebedfordNomad IIIJust ran the test - changed one character in the network password in the Bullet. My PC reported that it was still connected to the linksys router but that there was no internet. Changed it back and the PC had internet again.
I'm convinced that the Bullet is doing network security with the access point. - joebedfordNomad III
As an experiment, I'll change the password in the Bullet for my test network and see if it still logs in or if the PC is doing security. - LittleBillExplorer
joebedford wrote:
Eureka!
It took some poking around but I eventually discovered that the wifiranger people had changed the default IP address of the Bullet from 192.168.1.20 to 192.168.250.20. Once I configured the Bullet per the video you linked, I was able to drop in the WRT54G (configured for static IP address 192.168.250.21) and access the whole shebang via wifi.
WooHoo!
Only really odd thing is that the Bullet won't let me set the radio button that enables wifi security. But it does it, because the remote network I'm using for test is secured with WPA2-PSK. Whatever - it works.
Now, once again, I can overpower other RV park wifi users and stream videos all day ;)
thats cus the bullet is working in client mode, it has to match whatever the campground security is, you connect to the bullet via the linksys router and configure the wireless security settings there. - GordonThreeExplorerI think I'll get myself one of these to play with. I lost my external WiFi antenna from ice sliding off the roof - sheered the plastic antenna clean off. New one is going on the crank up antenna mast. Do they work with any regular n-type antenna?
- joebedfordNomad IIIEureka!
WooHoo!
Now, once again, I can overpower other RV park wifi users and stream videos all day ;) - LScamperExplorerI am doing what you want to do. First set up the bullet using your computers ethernet port.
This link shows how to do that.
Setup static connection
Then configure the bullet as in this link.
Configure Bullet
Then reset your computer as per the first link. After you have an internet connection you just connect the Bullet to the same port on your router that the cable modem plugged into. Set your computer to use WIFI. No other changes should be needed.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
