accsys
Aug 04, 2018Explorer
If you are used to using the Trav'ler and like watching in HD, you will be very unhappy with any dome as it will not receive the HD DTV channels, only SD and then, as said above, only for another year or so. We purchased a normal 3 LNB dish very similar to the Trav'ler in shape and mounted it on a tripod. After a little practice, I can usually hit the satellites and lock her down in about 15 minutes - the main thing is making sure the mast is absolutely plumb. That gives us the same reception as the Trav'ler.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 19, 2026
