buzzard616's avatar
buzzard616
Beware cheap short cuts
My signature TV is a 'Work tuck'. No fancy trim, rubber floors, etc. and no computerized driver information display. Trying to get mileage figures I used the gadget shown here to connect with an app on my tablet.
It worked fairly well but what it also did on two separate occasions was to throw the ECM in the truck into a coma. The biggest PITA was the transmission refused to come out of 1st gear. Had to stop; shut down; disconnect the battery; put it all back together and start again. After the 2nd time I suspected the wiz-bang gadget and pulled it. Hasn't happened since.
Lesson learned - I suppose there's a reason folks recommend the ScanGuage and not this thing. :S
Stu
  • buzzard616 wrote:
    With no 'preview' option here the only way to proof read and edit a post is to post it first and then use the 'edit' function.
    You can preview before posting. See above.
  • TucsonJim wrote:
    Not sure what the purpose of you post is???
    Sorry Jim. You read it before I was finished. With no 'preview' option here the only way to proof read and edit a post is to post it first and then use the 'edit' function.
    Point is trying the cheap shortcut as I did could have caused more than temporary damage to my truck.
    Stu
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,802 PostsLatest Activity: Jul 26, 2025
