mccoydetlef's avatar
mccoydetlef
camp ground cable into
ok can i convert incoming cable to HDMI my tv does not have a coxial input any help thanks and who has it OK my mistake it does have one but it was smashed up and then fell out it is a smart TV
  • Maybe the OP is using a monitor instead of a television. That's the only thing that would not have a coax input. If that's the case he would need to buy a TV tuner adapter and connect that to the TV via HDMI.
    Something like this:
    TV Tuner
  • I have never seen a TV without a coax cable hookup, a monitor yes but never on a TV. Strange.
  • delwhjr wrote:
    You will need a tuner of some type with an HDMI output. The tuner will need to be QAM and ATSC compatible to be able to use it on Cable systems and OTA antennas.
    This is fine for digital, but it is likely that an analog tuner will also be needed. There are plenty of digital tuners available, but not very many analog ones.
  • You will need a tuner of some type with an HDMI output. The tuner will need to be QAM and ATSC compatible to be able to use it on Cable systems and OTA antennas.
  • Some TVs have the F connector. What model do yoou have? What does the manual say.
  • i find that hard to believe if it does not have a tv tuner then it is a video monitor and not a tv. find the brand and model number on it and type those and the word "manual" into google so you can download the manual.
    if it does not have a tuner you will need a external tuner/cable box to be able to select the channels you want to watch.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
