Bill_Satellite
Sep 14, 2014Explorer II
Your cable input goes to one or more splitters and sends the signal to the various output locations. Unfortunately, satellite TV does not work that way so the one satellite input you have goes to only one location and should have a separate output plate or loose coax where your satellite receiver should be located. From that specific location you may be able to send the output from that receiver to the other TV's in the coach but all will be watching the same channel. If you want to be able to watch more than one satellite channel on more than one TV then you are going to need 2 receivers and 2 different input cables. Dish does have a special dual tuner receiver which requires a specific antenna that allows one cable to carry 2 signals but only one will be in HD and the other SD.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
