Bill_T
Aug 09, 2017Explorer
STB that is what we were told to use for the second (rear) tv. We tried both comp 1 and comp 2. It did not work for his situation. No signal on tv screen. Thanks for the suggestion tho.
First (front) tv is working well. To get around the absence of a hdmi connector on the receiver he is using the receivers satellite output via coax to connect to the tv ota coax connector.
As suggested, if we can get a second cable from the receiver to the rear tv and connect the cable to the satellite output of the receiver using a splitter we may have a signal. We will try this approach. If any of you have other suggestions please chime in.
Thanks all.
Thanks all.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
