ol_Bombero-JC's avatar
Oct 23, 2018
Cassette to USB ??
Have lots of old music cassette tapes. Went looking (Amazon) for
device to convert to USB (Flash Drive) MP3.
Found lots of 'em in the 30-50 dollar range (and up).
Tried one - doesn't work well (or at all) on 'automatic' - but seems to do OK on 'manual'.
However 'manual' means you must re-start at each new track (and listen for the end, etc.
Of course, maybe I just don't understand "Chinglese" directions..:h
Anyway - ready to return it and try another.
Anyone happy with a choice? Brand name?
Thanks!
  • A bit of a gray area but you presumably legitimately own the cassets and it's legal to make a backup so long as only one copy is in use (you can't make copies and hand out to other people), so just download clean copies off the internet and store the cassets so you retain proof that you purchased them.
  • do you mean 'convert to MP3 files on a USB stick'
    direct conversion and storage ?
    its still an Analog play to the converter soft/hardware input
    I thought you meant cassette to USB in on the PC ?
    audio capture and record on PC
    USB is a PORT/hardware standard NOT a Media Standard
    MP3 is a media standard
    either way, as long as it sounds good to you on playback, then you are good to go
    i'm no Audiophile, i have 'tin' ears
  • I have copied many tapes to my computer with good results. I wonder if the problem you are having is because you are using a player that has a dirty head. Clean the player's head with denatured alcohol on a clean soft cotton cloth (an old white T shirt) before copying.
  • rk911 - I was posting (or editing) while you were.
    My opinion of the quality was good - to - very good.
    You're supposed to pop the cassette into the device and it will copy a side automatically - and shut off when done. Either it - or me - aren't on the same page for automatic operation.
    If you saw the "Chinglish" directions - you would understand!..:R
    Manually you listen to the track, then push to record the next one.
    Does just fine - but obviously, very time intensive!
    No big deal - not much time invested - will try another.
    And....another thank you!
  • I was replacing my cassettes with CD's back in the 90's.. I held on to the CD's over the years and then copied them to an iPod.
    More recently, I visit the thrift stores and 'antique' stores and look for the old CD racks loaded with old CD's..
    Been able to find a lot good ol' stuff that I like for like $2 a CD.
    Even Walmart has those $5 CD bins and I've found a lot of stuff that works for me..
    Got some 1900 songs on my old iPod that I just plug into the truck with a USB cable and that's what I listen to now.
    I still find some stuff here and there, get some stuff off of itunes as the mood strikes..
    I still have my old Walkman too! ha, ha! Even a couple of tapes, but have not used tried them for years..
    Good luck!
    Mitch
    Thanks!
    buddy did much the same with older LPs. bought the USB turntable, the software, everything. spent hours on this project. the results..not good. the orginal LPs sounded much, much better. he ended up just buying new CD versions of those albums.
    save yourself a lot of time and heartache and either buy the CD version or download from itunes, etc.
  • monkey44 wrote:
    You realize those tapes will not sound clean due to the method of recording and transmission. I went direct from CD to USB in my laptop and the sound's not great. I imagine tape to USB will lose even more listening quality ...
    Should try one and check you like it before you spend all that time ... JMHO :)
    Mr Wiz & Monkey - I was ripping CDs to USBs when the flash bulb went off. CD to USB Results were very good.
    Monkey - I tried the result of a few cassette tracks on the 'manual' setting - with the same "good results" - or maybe my old ears don't know the diff between clean -or- dirty (poor) sound, LOL.
    On edit - I should add the cassette to USB device is a "stand alone" converter. It converts directly to USB.
    Amazon lists dozens of 'em - all from "overseas" sources, of course.
    Tested both results by listening to 'em on 2016 GMC (factory) Audio system via the USB connection.
    BTW - thanks for the replies!
  • sorry, i have never done cassette tape to mp3
    i have ripped/copied CD tracks to MP3, and those were perfect
    because they went from digital CD to digital mp3
    no cables no usb no analog conversion
    the wear factor of the tape causing noise in the audio will play havoc with automatic mode, on all but the most expensive conversion gear,
    and then maybe on that too
    if using that, i would just record the complete side of the tape as one audio file, and label them album name side-1, album name side-2
    and not try do to individual song/tracks...tapes arent made that way
    not like CDs
  • You realize those tapes will not sound clean due to the method of recording and transmission. I went direct from CD to USB in my laptop and the sound's not great. I imagine tape to USB will lose even more listening quality ...
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
