Dakota98
Jul 20, 2015Explorer
8ntw8tn wrote:
I tried something similar: our surround sound in the RV was connected to the tv by digital optical cable and my thought was to operate my headphones through the surround sound. However, something has interrupted the signal between the tv and the surround sound. I purchased a new optical cable but that didn't help any. I had the surround sound tested at Best Buy and it's working properly. I suspect the somehow the function on the tv is no longer operative, but haven't had any way to verify that. The converter that was suggested appears to be an inexpensive way to test that theory. If it doesn't work with the converter, either, it will be a good indication the issue is with the tv and not with the cable or surround sound. Thanks for the reply.
Are you using a "sound bar" set-up ?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
