Nutinelse2do's avatar
Nutinelse2do
Convert winegard sk3005 to swm
Afternoon,
Just looking for confirmation on someone who has done this..
I am thinking of buying a Winegard 3005 from craigslist and have read it can be converted to SWM model if I change the LNB to this for $91.00
http://www.satpro.tv/directv-slimline-lnb-kit.aspx
Is this correct?
  • Supplement follow up question...
    Can the SWM Multiswitch be mounted on top the RV? Would make my install easier if I only had to run 1 cable from roof to a hidden location rather than 4.
    That's where my SWM8 is mounted. Since there were already two coax's going from the Trav'ler to my DTV receiver we already had the one coax needed to go from the SWM to the PI29 located near the receiver. All the installer had to do was install 4 short coax's from the Trav'ler to the SWM8.
  • You really do not want to install the SWM inside. You will make your job much more difficult than necessary. Use 4 short jumper cables to run between the base of the Trav'ler to the SWM and then connect your existing cables to the outputs. If you like, install the SWM where it is located under the reflector of the antenna when stowed.
    It's fully weather proof buy you need to use compression fittings on the coax cables and some di-electric grease in the F connectors to ensure long term success.
